MM M 5 FRONT TIRES AND RIMS
lenray
I have 6.50 x 16 front tires on this narrow front tractor. Will rims from other tractors fit this tractor with a more modern tire--maybe a 15 inch tire.
Also what is the info. on the engine oil filter. Can I GET ONE FROM AN AUTO PARTS STORE. ???
The wheels are standard 6 hole implement wheels . Wix filter# 51118 avaible at Orileys or napa as 1118 and crosses to others .
So is that oil filter inside of the block??? Remove the bolts and remove the cover and the filter is inside of there????
AG Wheel Express in Mason City,Iowa has all kinds of frt wheels and rear rims. There's 7.5L X 15 and 9.5L X 15's that fit on 6x15 and 8x15 wheels. Let them know your putting them on a narrow front end tractor so they can get you the right back spacing.
They make wider 15 inch diameter wheels but even the low profile tires get really tall.
6.50X16 tires aren't rare. If you are going to go with a much wider tire you will have to go with an offset rim.
MMDEL
