MM Head Gasket
Troyer
New User
Would anybody have an idea where I could find head gaskets for a MM G1000 Diesel? Also need intake & exhaust valves and both valve guides. Any info would be greatly appreciated.
When I redone the heads on my G 1000 10 or 12 years ago, Welters sold me a set of valves with oversize stems and my machine shop reamed out the old
guides to fit. Welters said best not to mess with valve guides due to possibility of cracking head getting them out. Valves need to set in seats in
head to a certain tolerance or you will have hard starting. My new valves came with directions for the valves and my machine shop guy did an excellent
job. Tractor seldom turns over more than twice to start even in cold weather.
the valves cant get recessed too much as that causes less compression and hard starting. that is due to grinding the valves and seats then the valve sits lower. when u install new seats with new valves your golden.
