1951 R Rotor Cap
Depends on what engine, and if the last guy installed the distributor as in factory stock position, same as timing on the flywheel, depends on whether the last guy installed the flywheel corectly
Rich's Toys, Better revise your statement. You could be 180 degrees off on exhaust stroke.
MMDEL
This post was edited by MMDEL on 04/13/2023 at 07:52 am.
I use the post closest to the cylinder block, right above the wire going to the coil. And I dont think this distributor has ever
been removed.
