Keep me posted if you find anything that works well. The person that was making them in the past stopped doing it several years ago.
I've looked through the Steele Rubber catalog and seen a few things that were close but nothing was an exact match.
This post was edited by SWMolines on 03/31/2023 at 08:42 am.
If one been down that path.... Supposed to be same as some car or truck. If you could cross to an auto would be more hope to locate.
Have similar in a drawing. If not same will push windows out rather than being flush. Flat 3/16 glass in 1/4 bigger than hole. with that gasket.
Steele Rubber Co. makes those moldings for old Chevy trucks and the like. Don't know if they'd have what you are looking for, but might be worth checking out, if you have not already done so.
Before Rex Mercer passed, he told me about the person that use to fabricate the seals for the R-Cab from a special die he had made. He is no longer making them. It does not seem that they were the same as any other common seal out there.
I have seen some recent restorations that used a different seal that did not look bad.
Supposedly some car/truck used same gaskets. Glass dimensions different depending on gasket type.
Some have found something that was close and trimmed away the the parts that were not needed or could not be used.
Would be nice to see picture of finished one with newer gasket and whathad to be done to trim.
Unfortunately, I have never talked directly to anyone that has done it. Else, I would know what they started with to make what they used.
I'll post here if I learn anything. Your questions have made me start looking at this again. I have an RCab and a ZTX that need window seals.
