To clarify which part you are looking for, the rear lamp (work light) is the same (7 flat lens) as the headlights, but with a different mounting bracket, which was mounted high on the fender, facing backwards, in pictures Ive seen. The smaller tail light (red lens) apparently used a lighter duty sheet metal bracket in the only diagram I have, which does not show where it was mounted. This diagram is in my 1950 ZA parts book. I have parts books for 1949 R and ZA tractors but no diagram in either book. Will need to know which light you have before the question can be answered.
Apparently neither. R cab must have used their own. Microfische says only on RTI. Will have to check further. Has to be two hole mount on cab.Think has to be triangular shaped. Thanks anyway.
