3 point control lever
I've got this old 1961 Moline Jet Star
all cleaned up and ready to go out to
camp.
Power steering works, had to rebuild the
valve body.The 3 point works, goes up and
down, however I can't get it ( the 3
point)to stay in position. Pull the lever
up 3 point goes up let go of the lever
its spring loaded,and it goes down to a
stop on the bottom of its ( the control
lever ) mounting plate and the three
point goes right down to its bottom.
Is there an adjustment for this control??
This tractor was sitting out in a field
for years. Got it up and running after an
engine rebuild.Meet a little direction on
this three point control
Thanks in advance
You can adjust that stop. The positions are Up - Hold - Down. Just below that I believe there is a Temporary raise position and flote below that, I believe. You can try and hold your hand on the lever so it doesn't fall all the way forward when it kicks out. Kind of straight up is neutral or the hold position (approximately 3 back is up, 3 forward is down from straight up). If you get it there, note how far you move it forward to the down position and when it starts to go down. Then adjust the stop to the bottom of the down position.
Disregard, found my owners manual and after reading it a couple times while looking at the problem I managed to fiber it out. Worked just as it was supposed to
Thanks!!
