Company Logo (800) 853-2651 Shop Now
Minneapolis Moline Tractors Discussion Forum
twin city rod bearing
Troyer
01-24-2023 10:45:00
Can anyone direct me to a source for Twin City 21-32 rod bearings? The part # is TW278
Leroy
01-26-2023 12:38:34
 Re: twin city rod bearing in reply to Troyer, 01-24-2023 10:45:00
I don't think you will ever find a set. The bearings are babbit and poured in the conectiog rod and then ground for the crankshaft. If your rods are still in good shape you will have to find a place that can pour babbit bearings and send the rod to them to put new babbit in. I know there has to be places but finding them might be a problem.
molinegb
01-26-2023 16:14:14
 Re: twin city rod bearing in reply to Leroy, 01-26-2023 12:38:34
Have a full set with mains. As said odds are they will never fit crank unless rebabbitted. Have NOS set for a U no one wants.Odds are if one bearing bad whole bottom end should be done. Rebuilt would mean crank to be removed, sized and bearings poured to crank specs. Most shops won't pour unless they have crank.
molinegb
01-24-2023 15:58:19
Con rod bearing babbit. Same as MM GT. Would have set with shims.
Duey C
01-24-2023 12:42:33
Are you needing a TW27B? Easy to confuse the B and the 8.
From the two TW27B bearing halves, the TW25 rod and the TW83 pin bushing. All 17-28 parts also so it widens your search.
I'm on a long term hunt for a rod for a 21-32 power unit engine so your post is interesting.
This post was edited by Duey C on 01/24/2023 at 08:24 pm.
Troyer
01-25-2023 06:35:09
 Re: twin city rod bearing in reply to Duey C, 01-24-2023 12:42:33
Thanks for the info. Have you tried Stammtractor for the rod you are looking for?
53ZBU
01-24-2023 11:20:02
Those are a shimmed bearing. Are you out of shims? Normal procedure is to remove shims to compensate for bearing wear.
Troyer
01-25-2023 03:22:54
 Re: twin city rod bearing in reply to 53ZBU, 01-24-2023 11:20:02
I have plenty of shims. A piece busted off the bearing collar and got wedged between the crank and bearing. The grooves are too deep to machine down, remove shims and still be able to use it.
Dennis P
01-25-2023 05:15:52
 Re: twin city rod bearing in reply to Troyer, 01-25-2023 03:22:54
Interesting that you said piece broke off and damaged crank. Bearings too loose? Have you checked the clearances, especially to check to see if the journal is out of round? I had one that to get close to the right clearance at tdc/btc it made the crank hang up when at 90 degrees from tdc or bdc.
Troyer
01-25-2023 06:42:24
 Re: twin city rod bearing in reply to Dennis P, 01-25-2023 05:15:52
It looks like the crank is fine, it's the bearing that got chewed up. I haven't checked the clearances yet but will as soon as I find a useable bearing.
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce ... [Read Article]
Latest Ad: Looking for a Farmall super h steering housing the big cast piece in front [More Ads]
Copyright © 1997-2022 Yesterday's Tractor Co.
