Smoke out breather
Bigmo-utu
Got a 605b , water pump went so I put one in off of a 336a, just because I had one sitting right there. , start it up and its smoking bad out breather directly behind water pump. None out valve covers. Any thoughts?
When bolting the water pump on, a proper amount of shim gaskets need to be used so that the pump drive does not put axial pressure on the distributor drive. There is a brass thrust washer behind the distributor drive gear that gets hot.
