Engine stand
Oliver.88.MM
New User
Has anyone found a particular engine stand
they Like to use for big bell 6 cylinder engines?
To be able to spin over, and remove crank? Thanks
Thats a real good question.
My little three wheel allied one from a cheap and a lot store . It got a littte hairy rotating the Fordson engine . Almost tipped it over , lucky I was strong enough and quickly recovered .
Capacity and wheel base What I would look for .
I think that some auto parts rent them ,also maybe not. Thought they did at one time.
be a whole lot safer to put it upside down on a good work bench. i would not trust it on a stand unless both ends where supported, even then how do you expect to turn it over, it wont be by hand. chain hoist and work bench is the way.
Checkout a OTC Revolver made for large engines. But anymore they mount to the side of the engine. Have seen some stands made using an older combine final drive as the gearcase.
Can't get the photo to load, hopefully the link works. I built one that works well. Is adjustable height and used a work gear gearbox off a junk Ramsey 12k winch for the rotation. Plate has both large and small bellhousing bolt patterns drilled in it.
https://photos.app.goo.gl/4ujZ7FUGH6Mr8PED8[/img:b03f360153]
AL9nZEVufppq6x1Zvg_Ak5K1g85Lb9H2zRzlaPqrKmmkaXyaZFjdb2ocO38kkplqnyllZubKqVxEWgRDY8lzmqfG1IXIJUOA9etzf8rB3V7c6FLI0QfEv7AzTttipFfosTBQITx7Y6X3jH1Fm-wcGFsVxBBd5Q=w1039-h584-no
