KTA project update
Tom R S
My 38 KTA is tucked in the barn for the
winter here in Wisconsin.
Finally have a blanket of snow which looks
like it will last through Christmas.
I'm feeling good about my project. I
cleaned out the water pump and removed the
thermostat and it has been running well.
The oil is staying fairly clean and
pressure stays around 25 psi.
Starts easily - usually in about 3 to 5
cranks.
I'll probably re-install the stat next
year but for now I've been blocking the
radiator to bring it up to a good
temperature.
Moving my focus now to cleaning the gas
tank and repairing the steering gears
which need some bushings.
Would like to find a draw bar assembly if
anyone knows of one. Otherwise I'll be
having it made.
Pic is from last run outside earlier this
month.
KT/KTA steering gears and arm weak spot.. Hitch setup is to light. Have 6 and don't think any are decent.
