Farmerwright97
I'm finally getting started on my utu. The
plan is send the cam to Barry's for a
pulling grind and send the heads in fo get
resurfaced and new valves, one question I
have is has anyone put bigger valves in a
4210 head? And if so what did you use for
valves? Is there anything else I should
have done to the heads while they're at
the shop? The plan is be able to use this
tractor at a couple local pulls and still
be able to use it around the farm, thank
you for any insight and information
