Z pulley drive
Z drive won't work on 706.Way too small. Best drive and pulley would be 1952 and up U, will bolt right on. It can be disengaged whereas early ones run when clutch engaged.
Pulley for ZA is listed as Belt Pulley Rim, 15 O.D. x 7 face, part# 10B1044. All 18 parts of the assembly have individual part numbers.
As molinegb said a Z pulley housing will NOT work in a 706. But U s and G s are the same. I have both Clutched and Unclutched in stock. i am located in northern Illinois. 815.456.2114
MMDEL
I would have belt pulley and drive in MN if that is any closer to you on the map. Not a very shipping friendly item.
