Front suit case weights
KLW
New User
Im looking for some front weights for my G1355. Do the White
weights workIm not that particular about being genuine MM.
Or even if there are reproductions available?? Id like to get a full
set.
There is someone making new ones, I have seen them at the LeSueur swap meet the last couple years. Sorry I don t remember who was selling them though. Don t seem to come across used very often.
Was a guy in Wisconsin doing reproduction ones but I haven't seen his ad in a while. Later White weights will hang, bracket is the same. What would probably be correct is the 20- part numbered weights that did not have MM cast in them but are the same style casting as MM with the double handles which were for Oliver. I have a set of them I would maybe consider selling. I'm in MN.
Yes, white weights will work and generally are alot cheaper than MM weights. Oliver double handle weights will work also, look just like MM one but no marking
