MM Uni carrier parts wanted
Alan K
Anyone have any parts for one of these diggers? I need the large V bolt for the center support, one outside tooth assembly and one of the gears for the lift.
I have seen the JD ones. Wondered if they would fit. MM called it a toolbar but also a Uni carrier.
It is similar to a U bolt but fits around a square shaft and doesn't have a flat bottom.
No, it is a different set up. My TFA field cultivator has the same unit as the plow but these have a gear that is on the axle and
an open type gear box (so to speak) above it. I noticed one of the gears has several teeth missing. I will see if I can get a
picture of it tomorrow.
