M5 point installation
Setting the 3 pt back on the tractor after having adjusted the PTO clutch. Do those shims between the hitch assy. and the rear end case go above or under the gasket? Can't find anything definitive in my books.
If you are talking about the shims shown in the clip below, the go under the differential cover and should key into the gasket like a jigsaw puzzle.
