1969 mm M670 Super clutch pedal
Sounds like you have a key out of throw out shaft, Should feel clutch at 1-2 inches like Keith said.
it is strange b/c I can't feel when it starts to disengage but it is disengaging at what I would consider a normal travel distance. then the pedal just keeps going. since I don't have a step on that side, there is nothing mechanical to stop it until the linkage binds.
When pedal is up and released it will bottom out on the platform. Of the platform is off the pedal will travel quite a bit further.
you are correct about that! I don't have a step on that side. I removed an after market cab that was SHOT. the step on that side was removed and a
different step installed that hung off the cab. I am hoping to find a proper step in Albert City next weekend.
Now I am fighting an electrical issue. have a coil and points ordered. picking up wires and spark plugs tonight after work. This is the gift that keeps
on giving. Glad I found this message board. every one has been so helpful. I have looked through many strings to solve problems already. thank you,
everyone!
