Company Logo (800) 853-2651 Shop Now
Minneapolis Moline Tractors Discussion Forum
White 2-155 fuel gauge
robo76
08-02-2022 19:51:37
Looking for help with a white 2-155 fuel gauge. It always reads full. Single wire to the sender, but 3 wires to the dash unit.Any way to test the sending unit and the dash gauge? Thanks!
ChrisQ
08-03-2022 20:21:37
 Re: White 2-155 fuel gauge in reply to robo76, 08-02-2022 19:51:37
Please correct me if I am wrong, it has been a while since dealing with one but 2-155 has a tank under hood and also one under cab on right side. I think both tanks have their own sending units that feed back to the gauge. Should be able to use an ohm meter and sweep senders to see if they are working.[/code]
molinegb
08-03-2022 05:41:33
Sending unit is basically a variable resistor,usually low ohms. If sending unit open or wire to it will read high to supply voltage or as full tank. As tank lowers resistance increases and gauge goes down. By manually grounding wire to sender needle will zero. If so gauge is good and sender bad.
Alan K
08-02-2022 20:05:57
Usually when you remove the wire from the tank sending unit and ground it and the gauge goes to full the sender is at fault. If yours is reading full, there might be a bad spot in the wire that is grounding the gauge. I think most of the time if the sending unit is bad, the gauge usually reads empty.
Today's Featured Article - Threshin Demonstration - by Michael Delaney. Introduction I bring you greetings from Prince Edward Island, Canada. We are Canada’s smallest province but big on farming. Maybe you’ve heard of us. Potatoes are our biggest crop. However, there is lots of mixed farming here also. I have a small mixed farm with 25-30 cattle. I make very good use of old machinery. I have a 135 MF Diesel, Farmall H and 1/3 share in an Allis B. I have complete lines of tillage and harvest equipment, and a saw gear etc. I have everything one would ... [Read Article]
Latest Ad: Rubber pads for steel tracks 10 inches long by 4 and half inches wide 2 hole [More Ads]
Copyright © 1997-2022 Yesterday's Tractor Co.
