MM M5 RADIATOR
lenray
Is the radiator on this tractor and the power steering unit all one piece???? Anyone have a picture of the complete unit????
molinegb---Thankyou...What are a guys chances of unbolting the radiator without breaking off those bolts????My radiator looks really good everywhere, but leaks right there on the bottom...Thanks for your continued help....
If it is leaking at the bottom, check real close. It may be the gasket leaking and not the radiator.
MMDEL
M5 diesels we used in 60-70's were problems. Vibration caused most problems. Rad shop had made a special jig for doing the rad's. Usually leaked around bottom plate. Don't remember ever replacing one. Just solder back together. Bolts came out ok as tractor was fairly new then. Did a 5 Star few years ago and broke most off.
