1870 fan hub bearing number g995mm
AndrewJ
Looking for the manufacturer bearing number for the fan hub bearing on a 1870 white.. agco part number 10A29884.. unavailable from agco
(quoted from post at 11:19:13 06/09/22) Looking for the manufacturer bearing number for the fan hub bearing on a 1870 white.. agco part number 10A29884.. unavailable from agco
Is the original a ''unitized bearing'' or does it look like the substitute assembly in the parts drawing? (I realize this is not a waterpump, but some fan hubs use a waterpump-style bearing.)
Have you tried to get it from AGCO under the substitute part number 30-3412857?
If the original is a ''unitized bearing'' similar to waterpump bearing you could try calling the folks at the link below and see if they have any knowledge of it or could match it up by dimensions.
http://www.az-rpm.com/
