MM MO sickle mower.
T.R.K.
I just bought another MO(7) sickle mower. The 3-point hitch has me wondering if it was really all MM. If you guys have any pictures of MO sickle mowers, would you share them?
Thanks!
T.R.K.
If you are talking about the J7 mower, it was built by Schultz. That is the only 3 Pt mower MM ever sold.
MMDEL
Was MO not an Avery/MM built one? Know of one and did some research on it. The MM/Ol/Cock gets massive confusing. Someone
should sort of actual companies that made balers/mowers/ rakes/ combines etc. Have never seen accurate one of who made it?
That is why I asked for pictures. The lower 3 point pins look like they are on a factory made bracket, but it is different from any of the
other 3 MO mowers here. but the upper part of the 3 point is what I question. It has the remains of white paint on it too.
I have another MO(6) that has lower 3-point pins but it is on an adapter that bolts to the regular left and right pull links on the mower.
(I think this style is in my MO mower parts book. That one also uses a chain or link rod to lift the sickle bar, this works just like the
drawbar mount mowers that lift the sickle with a link from the rock shaft on the tractor.)
This new mower has a small hydraulic cylinder to lift the sickle bar. The 3-point lower part looks factory made but it is much heavier
than the 3 point mentioned above.
I wish I had a working digital camera.
Thanks for the reply.
P.S. I have a worn out J7 mower sitting here too.
I have 3 MO mowers also. Never paid much attention before, but looking in the parts book maybe this is what you have. A hitch assy . for a Ford tractor.
MMDEL
