1937 ZTU carb.
Just use specs of later Marvels. 3/4 turn on idle/mix and 2 1/2 on main jet as starting point and tune from there. Float lever should be parallel to carb top if remember right.
That carburetor has the round float if I am not mistaken. I am really thinking of the TRX carburetor.
I am thinking 1/4 from the top will work-(measure with no gasket), but some of the other MM guys will know for sure.
