336D questions
Ive just put the pan back on after a strung out rebuild. The IT manual says you need to reach in through the oil filter opening to reinstall two cap screws
at the back. I dont see anywhere to put them. That particular chapter refers to several models. Were there differences between pans? I have a bolt in
every hole (two long ones at the back). Looks good to me but want to make sure Im not overlooking something.
Secondly, how sensitive is the oil pressure regulator? Ive tried to make sure the adjustment hasnt moved but it might have shifted slightly.
Jack
IT manual just a poor guide. There is no screws in back of canister. Only on U diesel or Gv1. Two screws on canister face hold it in place. Has to be installed in pan goes into place. No reason to touch regulator especially on a rebuild, unless someone has been adjusting.
