Part # don't cross as UDLX. KTA and UDLX use same basic crankcase and gears. Seems to me the Delco number does. Hard to find for KT and GT also.
The drawing for the generator is # KE-562. You can get it from the Floyd County Museum. According to the drawing the part number for the generator is Delco Remy P/N: 1101659.
I went to a local business that rebuilds starters and generators and supplies other automotive electrics (Hagemeister Enterprises in Lebanon, OR (https://heielectric.com/ )) Larry Hagemeister had the exact generator (at least physically). I think he said it was out of an old truck and it was in his stash of used parts. I had him rebuild it for me to a 12V negative ground system since I wanted the electrics on the tractor revised to 12V from 6V. He also mounted a cutout on it that is identical in size to the original.
The generator had a gear on it initially but once removed is was the same generator as the UDLX dimensionally.
