M670Super PTO
molinegb
Know a guy that his pto bearing went out and piled clutch up. Would it be just as easy to install setup from a old M670? Or just change whole rear end?
The shaft between super and low band is a little different. Most of the clutch parts are the same. Swapping a rear end to fix a PTO sounds like the hard way to go about it. They are not heard to rebuild and give enough problems that I would not trust the one in a used rear end to last indefinitely.
