water tubes removal from head and cylinder block
Is there away to separate the head
section from the water tube that connects
the two sections. Same question in
regards to the cylinder block sections.
Should that not work any ideas where
icou!d buy the replacement tubes ??
The block and heads are heading to the
.machine shop thus the reason for
separating them
Thanks
Heads and blocks just pry apart. I always change water tubes and o'rings. If you they don't will leak.
Where did you find the tubes? Havent found any on line thought Id wait and see if somebody could point me in the right direction before I go thru the list calling about them
