Seized up Jet
This site and its members have helped me with my first Tractor, Ford 8 N and it came out just fine. thanks to all of you !
I picked up a M M Jet Star with one cylinder seized. Had been setting outside for quite some time. it then spent a couple years inside and
this is where I come in.
Got it home in the garage and found the P T O out put shaft wont turn either. P T O lever moves back and forth with a click at each end of
travel, but the shaft won't move in either of these positions.
I can handle the seized piston, but I don't know much about the back end of the tractor with the live P T O and the hydrulics.
got a shop manual and a garage to work in. Going to address the engine first, then work my way back.
Any ideas of what to look for, or where to start when I get to the P T O issue??
Thanks
Brian
I wouldn't be alarmed. It's a wet clutch and just the friction of the gear oil in the clutch pack can make it impossible to turn by hand. It's that oil friction that makes Minnies famous for having the shaft spin all the time. Not a big deal.
