1959 5 star - 3 point hitch won't go down
chrisaukcam
New User
The 3 point hitch will go up, but won't go down on my 1959 5 star. I tried to push it down, but it was solid as a rock. It has 2 levers on top of where the hydraulic fluid is under the drivers seat. Any adjustments here, or is it more complicated? It was working OK a year ago.
One is a cycle lever and one is the rate lever (rate of drop) You should be able to put your hydraulic lever into the lowering position and then move the rate lever under the seat either direction and see if they go down. I don't remember off hand if it is the upper or lower lever of the two.
