Snap over force for M602
Whats the correct setting for engaging the Ampili-Torq into direct drive? The IT manual is confusing - mentions both 35lbs and 55-60. Or is it enough to
just make sure it snaps over very positively?
Jack
Just a distinctive snap. To much will break fingers. Would never go by IT as just a guide and very inaccurate.
I believe if the force was below 35 pounds of push then it needs adjustment. Usually the upper number was properly adjusted with the tractor warmed up and not running.
