tele-flo hydraulic lever o rings
WI Lee
New User
Has anyone ever replaced the o rings on the control levers for the hydraulics? If so did you disassemble the whole unit or can it be done through the top cover for the rate and cycle levers?
I usually disassemble them but it can be done through just the rate and cycle lever opening. Have a couple good pen magnets handy. Trick I was told is to knock out the roll pin for the 3 point lever at the lever instead of in the control valve. This way that rod will still hold everything else in place when you slide out the two remote levers.
Thanks for the help. If you disassemble the whole thing do the valves have to be re adjusted?
I haven't had to on any I took apart. Just make sure to put everything back together the same as it came apart.
