1955 MM UB water pump and/or repair parts
mosem00
New User
Hi MM Enthusiasts and Experts,
Anyone know where I can buy a NOS or replacement water pump, or the parts to rebuild mine?
The replacement pumps I've found online have the intake coming straight in from the bottom of the pump, mine enters from the side (facing the radiator), so not sure if replacement pumps that say they would fit the '55 UB actually will??
Thanks!
Thanks, MolineGB. I should've mentioned, my UB is a gas model.
Do you know where to get the parts for the pump?
Thanks
Agco should have seals or Welters. Same water pump setup used from 1938-58 on all U gas. If need shaft and impeller probably try
used as lots of parts units.
(quoted from post at 16:18:57 02/22/22) Agco should have seals or Welters. Same water pump setup used from 1938-58 on all U gas. If need shaft and impeller probably try
Thanks again!
