Company Logo (800) 853-2651 Shop Now
Minneapolis Moline Tractors Discussion Forum
MM Uni Tractor V4 Distributor cap
Bozrae1617
01-12-2022 06:17:20
Trying to find the correct distributor cap for an MM Uni tractor with the V4 206 engine. The original distributor cap was lost and while another Delco cap will fit, the firing order on the distributor cam lobes for the points are not spaced an equal 90 degrees all the way around. A normal distributor cap has the plug wire outlets spaced at an even 90 degrees apart. This was discovered when setting the valve lash. The pointer on the distributor only lined up correctly with the replacement cap in 2 locations when the piston was on top dead center during compression stroke. The only way I can see this working correctly is with a special distributor cap. Attached are some pictures taken from the MM service manual showing the distributor cam rotation angles and the part #s for the distributor. If anyone may have the correct cap or any additional information, please let me know. Thanks, Steve
The MM distributor part# is: 10B1989 and the Delco-Remy # is: 1111559
MMDEL
01-19-2022 08:52:43
 Re: MM Uni Tractor V4 Distributor cap in reply to Bozrae1617, 01-12-2022 06:17:20
That rotor in the picture will not work. I have the right rotor. It is similar to the one in the picture, but not right. I have the right one in stock.
MMDEL
This post was edited by MMDEL on 01/19/2022 at 08:55 am.
Bozrae1617
01-20-2022 05:56:14
 Re: MM Uni Tractor V4 Distributor cap in reply to MMDEL, 01-19-2022 08:52:43
MMDEL-Thanks for your response. It's possible I may have already tracked down the correct rotor, but do not have it yet. How can I get in contact with you if I still need one? Thanks
wore out
01-17-2022 15:27:38
I looked at some older Ag and Industrial ignition info and the only thing I could come up in Delco with was the rotor shown below. It is only extended in one direction, and I don't know if it would work for your engine.
I have a distributor machine and have cut holes with a hole saw in spare caps and run a distributor on the machine, you can then see where the rotor tip is in relation to the cap terminals when the points fire the coil.
As a last resort if you can't solve this locally, I would be willing to do that for you and possibly modify the rotor as needed.
Bozrae1617
01-18-2022 06:11:26
 Re: MM Uni Tractor V4 Distributor cap in reply to wore out, 01-17-2022 15:27:38
The DR-321 rotor with the 'wing' off to the left looks just like the one on my Allis Chalmers D12. I'm not sure why Allis used that type of rotor on an inline 4 cylinder. I've also seen just a regular rotor on those same tractors so apparently either will work.
I did come across a Moline Uni distributor on Ebay with a what appears may be the correct rotor, it has the 'wing off to the right just the opposite of DR-321. The seller said he would sell just the rotor, so I'll probably go that route for now and see if that works.
A lot of good help and comments were provided on this forum, thank you everyone.
Tramway Guy
01-17-2022 14:41:31
Maybe you could find an 8-cylinder distributor that would fit mechanically. Then just use the appropriate terminals for the odd-fire engine. Ground the unused terminals, maybe?
The body and cap would necessarily be larger, but it might work.
Tramway Guy
01-17-2022 14:48:00
 Re: MM Uni Tractor V4 Distributor cap in reply to Tramway Guy, 01-17-2022 14:41:31
Scratch that idea. Youve got a 60 degree and 120 degree mixed in with the 90s. More like a V12 distributor. It has 12 terminals at 30 degrees apart. Probably harder to find than a special Delco rotor.
Tramway Guy
01-14-2022 20:14:43
The crankshaft is made with only two throws at 180 degrees apart, and both crank journals are shared by a cylinder on each bank. Its like two John Deere engines at 90 degrees off.
To have an even-fire V4, you need to have a crankshaft with four separate rod journals.
Tramway Guy
01-14-2022 20:09:15
And to make things even more frustrating, there is NO electronic ignition kit from Pertonix that works on an Odd-fire V4 engine. You are limited to points only.
wore out
01-14-2022 09:15:26
It is a V-4-engine, the combination of the arrangement of the crankshaft "throws" and the degrees of the "V" of the block cause the various pistons to reach TDC at uneven intervals, the camshaft is "ground" to make the valves cycle accordingly, and the lobes in the distributor are unevenly spaced so each cylinder fires in a corresponding manner.
Al nickel
01-14-2022 08:23:33
I do not understand how a 4 cylinder engine can run properly with distributer contacts not exactly 90 degrees apart Can someone explain this ???
molinegb
01-16-2022 17:20:04
 Re: MM Uni Tractor V4 Distributor cap in reply to Al nickel, 01-14-2022 08:23:33
MM made a V4 for Uni's. It used Z blocks and pistons. Later used overhead. 445/Jetstar blocks heads. Both were 206 cubes. Not many here. Have seen few in SK.
T.R.K.
01-12-2022 17:30:59
The Distribuitor cap was the same Delco cap as for the ZA, ZB, U, 445, etc. The 'real' issue is do you still have the rotor button? I had to re-use the old one when I got my Uniharvestor running back in 2001. The rotor button has a curved wing on it so some part of the wing is close to the post in the cap when it does the odd-fire thing. (Kinda like 'wore out's picture, but a Delco style button.)
I recall that NAPA had a Delco rotor button with a wing for some kind of Allis Chalmers tractor back then, the wing went the opposite way off the rotor button.
You probably already know this, but the Distribuitor in those V engines has to be exactly timed to the cams. No 180 degrees off and it'll still run stuff.
Bozrae1617
01-13-2022 05:03:33
 Re: MM Uni Tractor V4 Distributor cap in reply to T.R.K., 01-12-2022 17:30:59
Thanks for the replies. I didn't realize the rotor may be somehow compensating for the odd firing sequence. I don't yet understand how that would work, but maybe if I seen the correct rotor it would make sense. The Uni is not at my house, but I will check it out in a day or two to see what rotor it has on because I don't recall what it looks like. A little history on the machine; I'm part owner with a friend, we purchased it about 10 years ago and harvested a few acres of corn each year with it. It was running when we got it, although to me it didn't seem like it ran 100% correctly, but I've never heard another one running so maybe it was normal. It seemed to make adequate power for what it needed to do. About 3 years ago it developed a miss in the engine while harvesting with it. New plugs, wires and distributor cap where put on the machine. Don't know if the rotor was replaced, I wasn't there at that time. It didn't fix the miss firing cylinder however. What it ended up being was a broken exhaust valve spring. That head was pulled off and and valve job was done. The odd firing rotation was discovered when setting valve lash.
T.R.K.
01-13-2022 18:17:04
 Re: MM Uni Tractor V4 Distributor cap in reply to Bozrae1617, 01-13-2022 05:03:33
Its been over 20 years since I had mine running. As I recall, even when everything is running right they don't sound like an in-line four cylinder MM. The v-4 does sound best however when it is at governed throttle/fast idle or whatever you want to call it. the extra throttle shaft in the manifold just slows it down some, kinda like some of the MM power unit governors.
wore out
01-12-2022 10:02:57
[quote="CVPost-Bozrae1617"]
Odd-fire Wisconsin V-4 engines solve the problem you are seeing by using a rotor with a WIDE outer tip along with a "normal" distributor cap.
I suspect that may be what MM did?
Wisconsin rotor, won't fit yours, though, as it is for a Prestolite distributor, so far I haven't found a similar Delco.
Tramway Guy
01-17-2022 15:11:38
 Re: MM Uni Tractor V4 Distributor cap in reply to wore out, 01-12-2022 10:02:57
The Buick v-6 odd-fire engine used a rotor similar to the auto lite one you showed in the photo. Had a trailing clip at the end.
Bozrae1617
01-17-2022 03:57:09
Was able to get over to the UNI this weekend and see what rotor it had on it. It looks to be just your standard rotor. Not sure how long that one has been on there. I understand now how a rotor similar to the one in the picture that 'wore out' posted will work. Just need to find a Delco version of that or try to modify an existing rotor. The UNI we have is the valve in head version, with heads like the 445 etc.
Here is a picture of what is currently on the UNI. Thanks for all your help and comments everyone.
Today's Featured Article - Talk of the Town: Trailerin a Tractor, Chains or Straps? - by Staff. Another great discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: " I bought a trailer and plan to take my CASE VAS to some shows. I don't yet have anything to secure it to the trailer. So which is better to buy and use; the ratchet-type straps or binders and binder chains? ... [Read Article]
Latest Ad: Massey Harris 44 with widefront,power steering and cab. [More Ads]
Copyright © 1997-2022 Yesterday's Tractor Co.
