G1000 Vista Tilt Column Cover
SWMolines
Has anyone found a good option for filling the opening around the steering column on a Vista that allows it to tilt?
I don't believe the original parts are available any longer.
They used a billows style boots on theirs. And I have considered going that route but thought Id ask if anyone else has found a better solution first.
Clint Stamm was looking to have the Vista bellows reproduced. Check with him to see if he was successful.
I would try finding a Vista in a salvage yard that has a cab on it. Probably still be good as long as its still on the tractor
I'd had that thought as well. Still poking around to see what options are out there. Mine is entirely gone. I got the tilt pin freed up the other day and will be working on the dash in the next few months. I need to call Clint and see what he might have and then go with the best option available.
Does Enterprise Plastics offer one of those? I know they have the hand hole rubber grips.
I noticed the quote marks get removed... There should be quotes before and after the three words - gear shift slider.
Steve,
That does turn up some interesting options. Many look to be to small or narrow but it would be neat if one could be made using the Bentley part.
Thanks for the idea.
let me look and see this weekend i may have one off that parts vista that i have it had a cab on it so it may be decent like doug said.
I have one give me a call sometime 315-651-8876
