Company Logo (800) 853-2651 Shop Now
Minneapolis Moline Tractors Discussion Forum
Hydraulic Fluid?
Clyde in Colo
11-22-2021 09:50:27
have a 1950 RTU that has been in dry storage, and I hadn't run it for probably 10 years. Got it going again this weekend, but the hydraulic system is not responding. I haven't checked it yet, but am guessing it is low on fluid. I seem to remember using a red hydraulic fluid for this purpose years ago? Can't seem to find a specified product in my manuals. ATF work or no?
Tony in SD
11-25-2021 03:46:12
 Re: Hydraulic Fluid? in reply to Clyde in Colo, 11-22-2021 09:50:27
We had enough lettered MMs to spell words and all we ever used was ATF.
T.R.K.
11-23-2021 16:58:49
A couple thoughts: Check your engine oil. If it is over full it probably has hydraulic fluid in it and your pump is leaking hydraulic fluid into the engine.
The other thing is I filled my BG with less than 2 gallons of Dextron 3. (less than 8 liters.) And since an R would have the same reservoir, pump and cylinder, it should hold nearly the same amount of fluid except for the hoses will be longer.
MMDEL
11-23-2021 07:47:40
Yes ATF now called DEXTRON that is all I ever use.
MMDEL
molinegb
11-23-2021 08:35:19
 Re: Hydraulic Fluid? in reply to MMDEL, 11-23-2021 07:47:40
20 Litre pail of ATF 121$ 20 l of AW32 50$. MY MM's don't get ATF.
rustred
11-22-2021 18:43:42
yes it will work. but for steady every day use it does not have the same lubrication quality's. hydraulic oil is for what it say's and so is auto trans and so is power steering oil. u can use each one in any of the above if you were out stranded in the bush with no other way to get home. even engine oil will get you going. years ago a guy lost his auto trans oil with a leak . so he dumped gear oil in to get home. got him home. lol.
molinegb
11-22-2021 17:10:11
All MM hydraulics used a basic hydraulic fluid.(AW 32) In 60's we used out of MM gallon cans. Red ATF was only used in power steering.
Clyde in Colo
11-22-2021 13:17:11
Thanks Larry!
larry Mi
11-22-2021 12:50:17
Yes ATF type A
Today's Featured Article - The History of Old Abe - by Staff. The Case Eagle - Old Abe - is a well known industrial trade-mark throughout the main streets and countryside's of thousands of cities and hamlets in the United States and civilized countries the world over. King of the air, the eagle is an established symbol in American life and heritage. The Case Eagle Old Abe is far more than merely a trademark. He is a character out of history, a bird with a personality and a story all his own. The story begins in the early spring of 1861. In the wild nor ... [Read Article]
Latest Ad: WANTED Rumely Oil Pull Models W X or M [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
