clutch setting on a Jet star II
LAS
New User
I know some of ya all know the setting for the clutch pedal free play on a JetStarII. Would you be inclined to share that knowledge with me please? Also where is the best place to buy a clutch plate, pressure plate and throw out bearing for the same tractor? Thanks in advance
Just did my Jet 2 clutch. Same setup as on all Jetstar//U302. I had good button clutch from wrecked U302.
Freeplay should be about 1.5" movement at end of pedal. My local Agco dealer was able to get all the clutch parts. They have an account through Hi-Capacity which is a clutch rebuilder. Make sure to replace the grease hose for the throw out bearing while you have it split. Also wouldn't be a bad idea to replace the input shaft seal on transmission and rear main seal on engine.
