Gas engine model 425B-6
Don Myers
New User
I recently purchased an acreage in Alberta and it had a Massey Ferguson 95 Super with a gas engine model 425B-6. It needs new head gaskets and a starter. I haven't been able to find where to buy the parts. Engine serial number is 16101914. Any suggestions where I should check?
Thanks
Must be a lp converted to gas. Don't think any gas were made. Is same as a MM GV1. Gaskets same as U. Starter
would be same on Massey 97, G705,G706 etc LP . Motor is basically same as U except 6 cylinder. 4 1/4 bore. Serial
number is under battery box on transmission housing. Should be able to source here in Canada.
I also have a GVl (same as Massey 95) that has been converted to gas from propane. It uses a tank from the diesel model, and taps some manifold heat from the exhaust manifold. It had a Zenith carb from a Case L when I got it, but upgraded it to a MS with the correct spec. Runs like a Swiss watch, and is nice to drive. Some sources claim that M-M made some GVls in a gas model because service data has been published, but I don't know of anyone who has ever seen one.
I've sourced Fel-Pro gasket sets for this tractor from Napa. My local old-timey generator and starter man has no problem with these Delco units. Perhaps a local shop can service yours. unc
Further note to my post above. My starter and generator man is in Cranbrook BC. He may have a starter, or can build one from components. Napa in Claresholm AB has always been good for parts. unc
No gas models made. Parts books don't show any gas components. GV1 is not same as Massey 95. Massey 95 is same as
GB and only sold in Canada. Massey 95 Super is same as GV1.
