Moline kw disc handle
chcase
Looking to find replacement handle on
hitch of KW disc 12 foot. No luck at local
Salavage yards.Anybody know of any still
out there? Thanks
Picture of handle, if it will post
Thanks,The decals are long gone on this unit and the handle is not only bent but the threads are bad on handle and the threads are bad on the bracket also.I figured if I can't find a replacement then I would have to cut the threads off and weld a new length of thread shaft onto the handle
Why are you calling the disk leveling crank a handle?? I have 4 of those disks but I don't have any extra cranks. I had one where the threads were stripped in the yoke and I found a large nut with the same thread pattern to weld on top of the yoke. To do that first run the nut up on the crank and then turn the crank into any threads that are left in the yoke then run the nut down to the yoke so the threads all line up, then weld with a rod that will weld cast to steel.Good luck!
MMDEL
I was able to find a new oem leveLing
handle but the yokes are long gone.Will
have to weld a nut on it or weld the
inside of the yoke and re tap it out.
Thanks.
