Jersey Jim
New User
I have a problem with a 1969 670 Super diesel with closed center hydraulics and 3 speed torque. Hydraulic fluid is leaking from the hydraulic system into the transmission to the point hydraulic oil has come out from the gear shift boot. There is no leaking of hydraulic oil to the engine or engine leaking into the hydraulic oil. The only place I know that the hydraulic oil could get into the transmission is the little line that goes to the top link bracket.
If that is the problem, what is the problem causing the hydraulic oil to go thru that line? Thanks, Jim
