Raymond Rauch
Working on a MM G955. I have added hydraulic oil to the reservoir under the seat for the steering and remotes. Tractor only gets about 200hrs on it by end of summer. At end of summer the reservoir will be a gallon low. When I open the top plug to the rear end to check the fluid it flows out as it is overfilled. I am assuming the fluid from the reservoir is flowing into the rear end. Is this a big concern as the fluid is the same. Will this damage the tractor if used when over filled. I am assuming there is a gasket between the 2 that needs replaced. Thanks for any advice.
