G-VI hydraulic pressure?
To have any speed and strength with a backhoe mounted on just about any tractor of that era (short of one purpose-built for a backhoe), you would have to set up a hydraulic pump to run off the belt pulley drive or the PTO. I've seen a few different setups, some more professional than others.
The only Molines you will find with high pressure would be the
later G series with closed center hydraulics. I think G1000
Vista was the first.
