Mimi-mo 445 clutch pressure plate finger settings/dimens
30-06boy
New User
Im putting a clutch disc and pressure plate in my 445.my shop manualgives settings/dimensions as to where fingers need set on pressure plate with pressure plate installed.these dimensions out of my book look almost impossible to check...how do u guys setthese forks?with pressure plate installed there is play in the forks...slop.wiggle room.im thinking there should be some play for when clutch disc wears the fingers will be able to move too.im kinda lost here. The car/truck clutches ive done dont have adjustment to pressure plate fingers...
I've never checked a reman pressure plate. The fingers should be set by the rebuilder. I believe they are supposed to be measured and set on the bench before installing?
As others have said, the rebuilder set it up already. If you want to double check, measure the finger height from the disk hub to make sure the levers are all the same height.
