Company Logo (800) 853-2651 Shop Now
Minneapolis Moline Tractors Discussion Forum
TC/MM oil filters.
Duey C
07-21-2021 22:50:26
Some oil filter options have dried up for TC/MM engines.
Just a short snippet of what I know so far.
Fleetguard LF-584's need some help to correctly fit on the 11/16 oil filter stem.
I also found the Henry Leasing FE5905 filter is quite close but may need some "adjustments" to fit some filter housings correctly depending on which nut holds the filter housing down.
The TC/MM 11/16" stem is what gets us in trouble.
Perhaps you have a 1/2" stem on your MM.
Hah! I'd like to know that! And yet I'd like to know.
NOT to promote my own madness/thread but for a small amount of info on oil filters for my 21-32 see posts 915, 916, 919, 920 & 924 starting on page 46 here.: https://www.smokstak.com/forum/threads/twin-city-small-tractors-on-a-whim.180290/page-46
I try to share info as I learn more.
This post was edited by Duey C on 07/21/2021 at 11:31 pm.
Duey C
07-24-2021 01:03:59
 Re: TC/MM oil filters. in reply to Duey C, 07-21-2021 22:50:26
Crap, there wasnt much real info shared in that last post was there? A bit more is elsewhere here.
Lets look at the Henry KE-5905 ($35 bucks for me) and Fleet Guard LF-584 ($13 bucks) for a moment.
New filters. Very available.
1. Not bad. The tall nut. Perhaps a lock washer under the nut on the bottom of the stem would raise the filter a bit to suit this tall nut better.
Shown at the depth AS IF the housing were installed.
2. Felt-stack type nut. Wait. It seems a certain 1950 UTS has a similar short nut. Oh oh!
Please dont toss your filter element in and hope itll do its job.
This is a waste of an oil filter in my opinion with the gap. Pay attention.
You MM guys should also know what a felt-stack filter looks like.??? Maybe not.
I have one. Still in a 1930 KT filter housing. Cool.
Remember, the KT and MT were the older brothers to the MM U.
3. Big filters. Quite close to the size of original filter elements.
Was/is there enough room to pass oil around the outside of the filter? Small space.
4. Little fart. The IH Fleet Guard LF-584. We can see the top neck Im holding upside-down in the pic has been size-modified to fit the TC/MM 11/16 oil filter stems.
The bottom neck is fine on both filters.
5. Another option. The Henry KE5905 may want you to downsize the hole in the top neck if you have the short nut. Tin snips and a clamp.
The LF-584 IH filter top neck needs to be enlarged to fit the 11/16 stem then a piece of 3/4 heater hose and a clamp to seal and hold it in place.
A socket and a hammer to drive the top neck down and around the TC/MM stem.
I had to clean up the threads on the stem I used for testing.
This post was edited by Duey C on 07/24/2021 at 01:05 am.
Today's Featured Article - A Lifetime of David Brown Tractors - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
Latest Ad: Gemmer hydraguide 954 [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
