670 hyd pump
Is a 10A2836, or 10A23686 hyd pump still available? Or does anyone rebuild them? Mine is getting weak and should start looking for some ideas. Thanks
Pump not available for many years. Can be rebuilt. Is a Webster pump. Common on Jet 3,M5,M602,as well.
Hydraulic.net has the specs on those pumps and will build a new one if yours can't be rebuilt. They can cross the Moline #, but if I remember right, the Webster # is also stamped into the pump body.
(quoted from post at 13:48:39 07/10/21) Is a 10A2836, or 10A23686 hyd pump still available? Or does anyone rebuild them? Mine is getting weak and should start looking for some ideas. Thanks
They can be rebuilt as far as I know. Just did my M670 Super last year. Welters Farm Supply will have the parts.
My OTRTrucker found a good used one at a salvage yard along with some other parts. This pump is a later one so does not fit M5 or that type pimp. this one fits up front under the distributor. Thanks for the information tho.
