Avery BF Hydraulic Pump Shaft Seal
md2099
New User
Lost hydraulic fluid and I appear to have flowed into crankcase. Breather burped oil and hyd fluid. Pulled of pump and looking for shaft seal. Pump says Eaton G-1 135568. Is seal behind snap ring and bearing? Any part numbers or suppliers for shaft seal? Any other culprits to check? Also need to replace pump gaskets
Any input appreciated.
Mark
Well. DUH Area Code 662 shows to be northern Mississippi, I had always heard he is in Mississippi.
