ZTU rear rim
brian(MN)
I need to replace the rear rim on a 1947 ZTU, do I have to remove the big U bolt on the hub to get the rim past it? or is there enough room to snake it past. Another quick project that is taking way longer than planned. Brian
The time I did it, it took a combination of heat, hammering on the flats, and a 6 ft. pipe on the 3/4 breaker bar to turn those nuts. (About 25 years ago.)
