pointrow
MM M5 Has a hyd leak under the seat. Appears to be under the plate with 4 bolts and 2 lines coming out or through it. To remove the plate the tube with the brush stuck in it needs to come out. It swivels back and forth but doesnt want to be pulled out.
Does it pull straight up ? Or am I missing something?
Thanks
Pointrow
Tube with the brush is the breather for the rear end. It is regular pipe thread and has to be unthreaded from the top cover. Your hydraulics are probably in the way to do that. Pull the hydraulic unit off the tractor, then the breather will no longer be in the way. A lot easier to work on when it is sitting on a bench also.
