Talked to Pete Little today. Still makes MM mufflers!
MnBoy
OK, this is the story: Pete Little is still making and selling mufflers for the UB and other Moline models. This is his "hobby." He takes calls at 620-354-6468. He will give you a quote either for a steel muffler or a stainless steel muffler. You send him a check and he sends you the muffler.
Yes, he is still around and active. He closed his Little Shop some years ago and then joined a White Dealer. He stopped doing that and now is making mufflers and perhaps other parts for Moline tractors. He said that when he fully retires, he hopes to have a successor to the muffler-making business.
(quoted from post at 17:01:04 04/22/21) I run one of his mufflers on my 37 ZTU. Top notch. Sounds and looks great.
Thanks for the reply. I am anxiously waiting for mine to arrive for the UB. The "Stanley brand" muffler is just too loud. Not much better than running a straight pipe. Don't want to have to wear hearing protection when using the tractor.
Put the new Pete Little muffler on the UB today. This replaces the MM-4 Stanley muffler. The Pete Little muffler is just what I was looking for. Engine noise is pleasant. Not too loud. Check out this muffler if you are not happy with the other brands.
The manifolds on my U and both my UB's have been switched out over the years. I run Stanley mufflers on them, based on the measurement of the manifold outlet and the length I need. I believe two of them are running a muffler originally intended for a Massey and the other one is for a Case if I remember correctly. They look correct and sound good in my opinion.
Just out of curiosity, how much to the Pete Little mufflers cost?
(quoted from post at 09:39:20 04/28/21)
Some fine looking machinery there! Stanley may make some quieter mufflers than the MM-4, which I had on the UB. When you look down the barrel of the MM-4 muffler, there are no baffles, per se. It looks and sounds like a straight pipe. The Pete Little muffler was more expensive, but meets my needs and should last a long time. When you look down the barrel, you can see there are some baffles. What a difference they make! Cost? I will defer to Pete on this....let's just say north of $150.
Would you be so kind to give the muffler body's dimensions please?
Looking for a 2-3/4 inlet, about 4-1/2 diameter body and about 23 tall muffler for a near 30 year older tractor.
A predecessor truthfully.
Thank you. :)
EDIT: Talked to Pete and he said the big part of the muffler is 5 X 15 and said those are the replacements for the taller muffler I'm looking for.
2-3/4 inlet, 5 X 15 body, 2-1/2 outlet and 32 inches overall.
Rich, nice toys!
Thank you guys.
This post was edited by Duey C on 06/06/2021 at 10:45 pm.
