Company Logo Shop Now
Minneapolis Moline Tractors Discussion Forum
MM G-1000 diesel Valves
cstrucks
05-04-2021 07:59:08
Anyone got advice on how far the valves need to be seated into the head on a G-1000 diesel? Currently rebuilding one and have heard that if they are to deep it can make them not start good. Thanks
rustred
05-05-2021 08:20:11
 Re: MM G-1000 diesel Valves in reply to cstrucks, 05-04-2021 07:59:08
who is doing this valve grind, you or the machine shop. to be totally in spec replace the seats and valves if they look that bad. yes valve recession is critical to any diesel engine for starting. as you know anytime the valve and seat is reground the valve will sit lower in the head. plus you need to look at the valve margin to make sure there is enough meat there to grind the valve. any machine shop will know all this info also, thats why i asked who is doing this work?
T.R.K.
05-04-2021 18:27:56
You might call Welters Farm Supply in Verona MO. They can tell you. They also advertise an oversize valve for those engines, that I think helps with the 'losing compression' problem.
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You ... [Read Article]
Latest Ad: Farmall A. A complete restoration of a 1939 Farmall A. Parade ready. Whole motor has been went through. New tires. Everything factory except the stack. Crank start only. OBO [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
