Company Logo Shop Now
Minneapolis Moline Tractors Discussion Forum
Moline GB Diesel intake heater
Jvoss
05-03-2021 11:30:16
Recently purchased a GB diesel. Everything is there and hooked up for the intake heater set up but Im wondering how exactly it should work?? How do operate the pump and switch in the correct way for starting?? Thank you
Also it has no serial number plate anywhere on the tractor. How can I determine the year of the tractor??
rockcreek4630
05-03-2021 14:26:56
 Re: Moline GB Diesel intake heater in reply to Jvoss, 05-03-2021 11:30:16
Dieseltech
05-03-2021 12:54:58
What type intake heater? Electric coil or Thermostart fuel intake heater?
Jvoss
05-03-2021 13:19:04
 Re: Moline GB Diesel intake heater in reply to Dieseltech, 05-03-2021 12:54:58
Its got a spark plug in the intake and a ignition coil mounted next to it and then fuel lines running back to the hand pump at the operators station. Not even sure if it works just wondering how youre supposed to use it technically. Acouple pumps and then hit the switch? Is it suppose to have a switch you hold down?
molinegb
05-04-2021 05:09:16
 Re: Moline GB Diesel intake heater in reply to Jvoss, 05-03-2021 13:19:04
More of a decoration. U/UB diesels had same option as well as Massey 95. Never have seen one that worked. Pull switch energized coil. Another option was an ether bulb. I just use ether.
Today's Featured Article - Product Review: Electronic Ignition - by Staff. Oil, for example has come a long way in the last 50 years and I don't use anything but the latest API grade available. I've heard the arguments for non-detergent oils but would never trade it for today's formulations. Paint is another, the modern acrylic enamels are great for resistance to grease and fuel stains, retaining their shine and they last forever; unlike enamels and lacquers . Still another is the alternator. No doubt using the original generator keeps the tractor pure, but for thos ... [Read Article]
Latest Ad: Armstrong 11.2x24 4 ply new never run,mounted on Allis B or C rim [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
