M-602 Final Touches
cleddy
I am trying to put the final parts on my M-602. Wondering if the fenders are susposed to be level or angled up in
the front. They are pitched up because that seem to be how the holes lined up. Lots of little things need tweeked
after a total teardown. Thanks for any help? cleddy
Looking good, that's a nice bright yellow that sets off the black stripes. Makes me wish the M 670 we had was still around.
I don't know if I should be sad or happy-better go with happy? I took the hood off because gas tank sits to low and hits the side panel wrong and hood did not fit right. Noticed gas gauge screw on tank was loose and thought wire came off and was hanging down by dash somewhere. Raised the tank a 1/4 and pokeing around looking at wires and all the sudden must have shorted out light switch and quickly had a hot wire and small fire? Not a good place for a fire and I have a disconnect on battery so easy to cut power.
Apparently my wiring job was about a 1/8(too close) to a disaster that could have happened when I wasn't there. I have to redo-Re-Imagine that whole electrical situation before putting all them hood bolts back in???Cleddy
Beautiful job,but are the front weights suppose to hang down a tad,just curious why did they design it that way ?
The Weight bracket came with the tractor and the weights hook over it and hang down and inner lock on the bottom. The next ones hook over and inner lock on each one. If you go over rough ground they can flop around and bounce off. I think there is a small bolt hole in them to secure each weight on. I'm glad I have them but prefer not to use them. Probably should put them on if I go to a tractor show??Cleddy
