New style oil filter
DIM
What oil filter do you use when you put a spin on oil filter on a ZA. I got the adapter to change over
I checked it out and my adapter has a different thread. Someone told me I need a NAPA 1061 that does not have a anti drainback valve because the oil goes thought backward. I'll have to check this out. Thanks anyway
NAPA 1061 is what is on my ZB. Be sure it has no drain-back valve in it. (in most cases, if you can see rubber through the holes, it has a drain back valve.)
How right you are I double checked and the wix filter and napa 1061 all have the same thread. The internet site I went to said wix was 1 inch in diameter. I must have put the wrong number in the internet site or the internet site was wrong. But the internet is never wrong right.
My R and my ZA both have Wix 51061 filters, which I believe is the same as NAPA 1061. I got my adapters from Charlie Biler and that is the one he said to use.
He also gave the Wix 51794 (NAPA 1794) as an alternate. I believe these have the longer body which more closely resembles the length of the original canister, which apparently is important to some people.
